Budget (including currency):  $4000 USD
Country:  USA
Games, programs or workloads that it will be used for:  Mostly gaming, but can be used for development or video editing.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):   Need something portable for road trips or around the house.
I know the H1 isn't the perfect mini ITX case, but from the reviews and parts availability, I can get a case, AIO and power supply which I know is compatible.  My biggest concern is cooling the CPU so I may step down to the 8 core 10700k.
I will also look at some of the higher end EVGA cards since they do sell a 2 slot replacement bracket for the 3 slot cards.
What other components are missing besides OS and kb/mouse.
https://www.nzxt.com/products/h1-matte-white
PCPartPicker Part List
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor  ($529.99 @ Best Buy)
Motherboard: Gigabyte Z490I AORUS ULTRA Mini ITX LGA1200 Motherboard  ($259.99 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 CL14 Memory  ($234.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($139.99 @ Adorama)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive  ($189.99 @ Amazon)
Video Card: EVGA GeForce RTX 2080 Ti 11 GB Black Video Card  ($1299.99 @ Adorama)
Total: $2654.94
Generated by PCPartPicker 2020-06-29 10:18 EDT-0400
Gaming - AMD TR 3970X | ASUS ROG Zenith Extreme II | G.SKILL Neo 3600 64GB | Zotac Nvidia 2080 Ti AMP | 2x Sabarent 1TB NVMe | Samsung 860 EVO 1TB SSD | Phanteks Enthoo 719 | Seasonic Prime Ultra Platinum 1000w | Corsair K70 RGB Lux | Corsiar M65 | 2x ASUS Rog PG279Q | BenQ EW3270U | Windows 10 Pro | EKWB Custom loop
ITX - Intel i7-10700k | Asus ROG Z490-I Gaming | G.SKILL TridentZ RGB 3200 32GB | EVGA 2080 Super| Samsung 970 Evo 1TB | Samsung 860 Evo 1TB SSD | NZXT H1| Windows 10 Pro
HTPC - Intel i9-9900k | Asus ROG Maximus XI Code | G.SKILL TridentZ RGB 3200 32GB | EVGA 1070 | Samsung 970 1TB | WD Blue 1TB SSD | NZXT H700  | EVGA G3 1000W | Corsair H150i | Windows 10 Pro
Servers - SuperMicro 846 | 2x 2695L V2 | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 24 x 6TB | FreeNas - SuperMicro 826 | 2 x 2695L | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 8 x 10TB | 847 24 x 1TB SSD | Windows Server 2019
Work - Dell XPS 15 9560 | i7-7700HQ | 32 GB RAM | 1TB NVMe | 4k dsiplay
https://linustechtips.com/topic/1215814-mini-itx-build/
lmao where is your cooler? or do you already have one. other than, it looks solid.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1215814-mini-itx-build/#findComment-13768872
H1 includes cooler
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
https://linustechtips.com/topic/1215814-mini-itx-build/#findComment-13768884
Just now, Zberg said:
H1 includes cooler
oh really? that is cool. air cooler? quality?
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1215814-mini-itx-build/#findComment-13768888
It comes with a NZXT SFX power supply and NZXT AIO along with the case for $340.
https://linustechtips.com/topic/1215814-mini-itx-build/#findComment-13768915
dang that is pretty cool. not sure if a single fan rad will be able to handle the inferno of the i9 with limits removed but it will be better than most other options.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1215814-mini-itx-build/#findComment-13768926
aio, and with a 650W gold rated PSU
here a 9900K and 2070S with that case :) JAYZ2C
CPU Ryzen 7 5700X @-30 || Motherboard MSI B550-A PRO MAX || RAM Team T-Create Exp 3600Mhz C18 || GPU Gainward RTX 3060 Ti Ghost || Case Fractal MiDi R2 || Storage 980 1TB - CS2241 1TB - WD10EARS - 3x ST2000DM008 - WD30EZRX - ST4000NM003 - 3x ST4000DM004 || PSU Corsair RM550 || Display(s) Philips 242M8 - LG 22MP65HQ || Cooling Thermalright Peerless Assassin 120 SE || Keyboard Topre Type Heaven - Akko 3068 - Vortex GT9 || Mouse Logitech G403 Prodigy || Sound Moondrop Chu 2 || Operating System Windows 10 Pro 22H2
https://linustechtips.com/topic/1215814-mini-itx-build/#findComment-13768947
It actually looks like the Microcenter in town has all the parts in stock including the case.  I will go with the 10700k to cut down on some of the heat.  Reserving the parts now and will probably put it together later this week.
https://linustechtips.com/topic/1215814-mini-itx-build/#findComment-13769052
