Does a cpu cooler backplate comes with the motherboard?
Are there any types of cpu cooler backplates?
-Main PC-
CPU Ryzen 3 3100 | | Motherboard ASRock B450M-HDV R4.0 | | GPU PowerColor Red Dragon RX 580 | |RAM 16GB Patriot Viper Steel 3000MHz | | PSU Corsair CX550 80+ Bronze | | SSD Kingston A400 240GB | | HDD Seagate Barracuda 1TB 7200 RPM  | |Case Phanteks P300
-Laptop-
HP Elite 820 G4
Intel I5-7200U
Intel HD 620
8GB DDR4
500GB SSD
https://linustechtips.com/topic/1215763-cpu-cooler-backplate/
usually it comes with a backplate
if it doesnt use the stock backplate from the MB
CPU Ryzen 7 5700X @-30 || Motherboard MSI B550-A PRO MAX || RAM Team T-Create Exp 3600Mhz C18 || GPU Gainward RTX 3060 Ti Ghost || Case Fractal MiDi R2 || Storage 980 1TB - CS2241 1TB - WD10EARS - 3x ST2000DM008 - WD30EZRX - ST4000NM003 - 3x ST4000DM004 || PSU Corsair RM550 || Display(s) Philips 242M8 - LG 22MP65HQ || Cooling Thermalright Peerless Assassin 120 SE || Keyboard Topre Type Heaven - Akko 3068 - Vortex GT9 || Mouse Logitech G403 Prodigy || Sound Moondrop Chu 2 || Operating System Windows 10 Pro 22H2
https://linustechtips.com/topic/1215763-cpu-cooler-backplate/#findComment-13768442
On AMD almost all coolers use the stock backplate from the mobo. On intel most coolers come with their backplate. Either way you won't have to buy one extra.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1215763-cpu-cooler-backplate/#findComment-13768449
