Is this build all evenly matched without any thing too powerful or weak with everything compatible?
-AMD Ryzen 3 3300X;
-Asus ROG STRIX B450-F; (If this isn't good for this
 does anyone know of a micro ATX instead)
-Corsair vengance RGB pro (2x8gb) DDT4-3200
-WD blue 1tb 7200 rpm hard drive data
-WD Black SN750 250 GB NVMe PCIe 3 SSD
-Gigabyte GeForce GTX 1650 4gb Windforce oc
-Corsair CSM 450W 80+ gold semi-modular ATX
 power supply
https://linustechtips.com/topic/1215532-does-this-build-work/
what's your budget for this build?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1215532-does-this-build-work/#findComment-13766795
Looks fine. Graphics card is a little on the low side.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1215532-does-this-build-work/#findComment-13766810
9 minutes ago, AnonymousPerson123 said:
Just want a good mid range pc for about £500-£800 ideally but willing to go a bit above
you can get a better system for that amount
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1215532-does-this-build-work/#findComment-13766866
