Hello, New PC gamer here. Ive built a pc, and everytime I try and play fortnite, my game seems to randomly drop from 120fps to like 40-50, then back up to 120.. and my radeon software says my gpu is spiking up and down from 0% to 100%... im so confused, i need help.
https://linustechtips.com/topic/1215230-fps-drops-and-stutters/
Specs ?
Do you have xmp/ docp enabled ?
Temps ?
Give sufficient information.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1215230-fps-drops-and-stutters/#findComment-13764979
11 hours ago, TofuHaroto said:
Specs ?
Temps ?
Im not sure what xmp/ docp is. im new to this stuff again, i built my pc and left it as it was other then making sure my ram was running at its rated speed. I have a ryzen 3 3200g paired with a rx 570, 2 tb hdd and 126 gb ssd.
https://linustechtips.com/topic/1215230-fps-drops-and-stutters/#findComment-13766607
Make sure it's on in the bios
Use hwinfo64 or cpu-z to check your current ram speeds
Check temps
And if that didn't work try ddu
Build Log:
https://linustechtips.com/topic/1215230-fps-drops-and-stutters/#findComment-13766614
Check temps
I have 16gbs of ram, and they are both running at the rated speeds. My temps are about 40-50° when idle, and around 60-70° when playing games.
https://linustechtips.com/topic/1215230-fps-drops-and-stutters/#findComment-13766676
