A few questions on my cooling setup
Vamo_Elysian
Hi all,
I recently bought a new, much larger PC case, and after setting it all up, I decided that I want to add an additional 2 x 140mm fans to the bottom.
However, looking at the specifications in the manual for the case, it states that to install 140mm fans on the bottom, I require a "bracket". I was wondering if anyone could point me in the right direction?
Also, what are the recommendations for bottom case fans? I assume I want to install them as "intake" fans, but, the way the case is set out, they won't be visible, so i don't need any flash RGB fans, what would be the best to get?
My final question - As part of the rebuild, I swapped over to an H150i AIO cooler, which came with 3 fans to install on the radiator. According to the manual, Corsair recommends installing the fans as "intake" fans, however, looking at the front of the manual the picture clearly shows them installed as exhausting the air through the radiator? I've mounted the fans on it as shown in the attached image, with the radiator mounted at the top of my case, and the fans pointing down into the case with the logo facing down into the case as shown, if i'm right, then that means the fans are sucking air from the case and pushing it out through the radiator right? Is that right or should I flip the fans?
Sorry for all the move questions!
Thanks all!
Dale
You would have to specify what case you have.
They should be intake. If you have a lot of room under your case go for an airflow optimized fan like the Fractal Venturi HF fans, if it is a very slim space then go for a pressure optimized fan like the Fractal HP fans. Those are what I tend to use, so they are easy for me to recommend.
The best would be to have them as intake in the front of your case. If that isn't possible, then you have to decide between top intake, and top exhaust. The choice depends on the air flow in the rest of your case, but in my experience, using it as intake provides better temps for the CPU and worse temps for the GPU, and using it as exhaust has better temps for the GPU and worse temps for the CPU. I have always settled on exhaust through the top radiator.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Hi, thanks for your response!
Silly me, I should have specified the case! Here's a link to the product page:
C700M
It seems like it would have plenty of room, so from your recommendation, the Fractal  Venturi HF would be the way to go.
As for the cooler, yeah it's probably possible to move the radiator over to the front, i'll take a look at doing that! For now i'll keep them exhausting
You don't have to get those in particular. Any airflow optimized fan will do. That's just what I tend to use.
Sounds good!
C700M
Hmmm. I think THIS is the bracket, but I don't know how useful bottom mounted fans will be in that case. Is there space for the air to get from the PSU basement up into the primary chamber? If there is limited space for the air to squeeze up into the primary chamber, then it might be best to go with a pair of pressure optimized 120mm fans.
Up to you though. GL!
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
With this case, the section at the bottom containing the PSU is covered by a metal plating that can be entirely removed, it;s just there to hide the bulk of the wires and make things look a bit neater. SO i suppose, removing it would better suit the 140mm AirFlow fans, but keeping it on would be better suited to 120mm SP fans. Seems i have a choice to make!
When looking at fans, I assume they clearly state somewhere on the specs if they are SP or AF optimized? Thanks!
The good ones should. Generally though, airflow fans have steeper angled blades with gaps in between them, and pressure fans have shallow angled blades with little to no gap. Pressure fans also tend to have higher RPM than their Airflow counterparts.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
