Looking for some help with a case upgrade. Currently running a Fractal Design Meshify C with 2x 140MM Noctua Intakes and a Noctua 120MM rear. My GPU temperatures are higher than I would like even with a more aggressive fan curve. Wondering if anyone can recommend another case that may improve GPU temperatures or possible a better fan curve?
My thought is due to the compact size and how close it is to the fan that it may not be getting adequate cooling or maybe heat can't escape fast enough?
If anyone has any suggestions let me know.
Specs:
I7 8700K
Noctua NH-D15 Cooler (one fan currently)
Asus Z370-E Motherboard
Asus Strix 1080 Graphics Card
16gb Corsair Low Profile DDR4
1TB Samsung 970 EVO NVME
500GB Samsung 960 EVO NVME
EVGA 650 G3 Power Supply
2x Noctua NF-A14 (Intake)
1x Noctua NF-F12 (Exhaust)
https://linustechtips.com/topic/1215035-case-recommendation/
Just now, rapidkillerx said:
meshify c is supposed to be one of the best for airflow
And one of the
If not
The best case :P
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1215035-case-recommendation/#findComment-13763272
Just now, TofuHaroto said:
And one of the
If not
The best case :P
lol i was thinking of your sig as i was saying that
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
https://linustechtips.com/topic/1215035-case-recommendation/#findComment-13763275
3 hours ago, ChaoticFury09 said:
I mean that was the reason I bought it. My CPU is normally fine, sits at about 54-60 under load. The GPU is anywhere between 67-75.
You are only going to get slightly better temps even with the best case compared to the Meshify C. You even added fans that are better than the stock fans included.
Your GPU temps are fine, you aren't going to get much lower without replacing the cooler on the GPU either with an AIO cooler and the NZXT Kraken G12 mounting kit, or a EK waterblock, but that requires custom loop water cooling.
Even open-bench testing shows the 1080 Strix heats up to around 67C under load. The fact that your case is almost equal to slight hotter than an open test bench is a good thing.
So basically, you have no issues with the case itself, but the only real way to lower GPU temps any further is to go to water cooling.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1215035-case-recommendation/#findComment-13764101
Thanks for the explanation. I was assuming the GPU would be cooler and that 75 was on the high end. At what GPU temperature should I get concerned?
https://linustechtips.com/topic/1215035-case-recommendation/#findComment-13764223
As long as it doesn't hit above 90C, you should be fine for the most part.
MAIN PC:
https://linustechtips.com/topic/1215035-case-recommendation/#findComment-13764246
