Ok so I have this old office computer, and I wanted to turn it into a decent performance gaming computer (first time PC building) and I was thinking of adding a MSI GeForce GTW 1050 Ti, at the moment the cpu is Intel Core i5-2400, 420 W power supply no Graphics Card and 8gb of ram, with this gpu there is a better one or bottlenecking? I was thinking of playing call of duty, rust, farcry. rainbow and others Thanks for the help! :)
https://linustechtips.com/topic/1214464-office-computer-upgrade-help-pls/
Assuming this PSU doesn't have a pcie connector
The best possible GPU you can get is a 1650 , if it does have a pcie connector consider a 570 which should cost around the same as a 1050ti but will perform better
Phone: Pixel 3a (Purple-ish).
Build Log:
Would go for the 570 variant. Trusted for (low budget) entry level gaming
Needs a pcie connector
Not suitable for every situation
Build Log:
3 minutes ago, Pieforlife said:
but im not sure if it has the cable
This is a pcie connector
Usually says vga on it
Build Log:
8 minutes ago, Pieforlife said:
would you recommend a 1650 or 570 with a new psu?
1650
And no not a new PSU
They are most likely proprietory
Meaning that the motherboard will only work with the current psu
Build Log:
1 minute ago, Pieforlife said:
then it wont severely bottleneck or anything else with a cpu of intel i5-2400
It will bottleneck
It won't be huge tho and it will still be an upgrade
Build Log:
