ok so i currently have an ASUS CH7 HERO non WI-FI motherboard inside my enthoo primo case. i currently have 11 fans in the case powered using either splitters attached the MOBO fan headers, or splitters attached via molex connectors.
i want to add another 2 fans into the case only problem is i dont have any molex connectors left and i can only add so many molex to fan adapters/splitters before the wire become over powered
are there any sata to 3pin fan splitters or do i have any other options
below is my psu in case it matters just looking for some options
im just lost because i dont have any spare molex power plugs on my PSU or spare headers on my mobo
https://linustechtips.com/topic/1214319-need-help-adding-more-case-fans/
That's a BEAST of a case...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
Thirteen fans shouldn't be a problem for the number of fan headers your mainboard has, even on triple splitters, as a last resort.
If they're on mainboard headers, they shouldn't need any molex connectors.
WHY NOT...?!
All the 4-pin headers are 12v so I see no reason why they can't all be used for fans... with the exception of 3:
CPU_FAN (CPU cooler needs to be on that one), H_AMP & W_PUMP+.
EDIT:
5 usable headers w/ three fans on each = 15 fans & NO Molex.
WHY NOT...?!
EDIT:
@Eighjan didnt know you could put 3 fan splitters on all the headers problem is i dont think i have a header close enough to the back side of the case i.e. the back on the mobo where the psu sits
Anything tagged with 3 is a fan header; CHA_FAN1, for example (behind the rear audio I/O).
CPU_OPT & AIO_PUMP could be used as fan headers, but I'd concentrate on 3-way splitters off the CHA_FAN1, 2 & 3 headers first.
WHY NOT...?!
