Budget (including currency): 10,000 Tk (With PSU), $120 USD
Country: Bangladesh (Asia)
Games, programs or workloads that it will be used for: Playing Games with low to Medium Settings. Photoshop & Illustrator too.
My Config:
CPU: Core i3-3240, Expansion Options: (PCI Express Revision: 2.0)
GPU: Intel HD Graphics 2500 (Base Frequency: 650 MHz)
Motherboard: Gigabyte H61M-S2PV (rev. 2.2), Expansion Slots: 1x PCI Express x16 slot (3.0)
RAM: 4GB DDR3 1333 MHz
SSD: 120 GB
My Question:
This is my current build (from 2014). I want to upgrade my pc with a GPU for little graphics performance boost. I got confused because my CPU supports PCI Express 2.0. But My motherboard supports PCI Express 3.0. I though about GT 1030 2GB, But I don't know If that'll bottleneck or not. Please Help. Thank you.
https://linustechtips.com/topic/1214053-need-help-with-gpu-selection/
that sytem is really bad for gaming. i would sell the system and look used systems online. otherwise get rx 470 or rx 560 used depending on your psu.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
My Config:
SSD: 120 GB
My Question:
What Power Supply do you have Aya? Also are is your computer in a full size case?
Edited by INurHome
1 hour ago, Ayazuddin said:
A normal psu. maybe 200-250W. It was very cheap. I would buy one if I need.
Is grabbing a hd 7950/7970 for about 30-50$ equivelent an option? And then picking up a system power 9 400/500w or a cx450/550 or CV650
Hello Brother
First of all I would not go further with this build. I would suggest you to save the money and go for an AMD build later.\
Secondly if you do want to upgrade, and concerned about the bottleneck issue , I am concerned if your CPU will work with the 1030, cz your CPU supports upto PCIe gen 2. Even if it did it'll get half the performance...Yeah so , not an option on upgrading your GPU , upgrade your CPU first
