Hi guys,
Over the past few days, the weathers been really hot. I’ve had a problem where my graphics card keeps reaching a temperature of over 90 Celsius. I’ve got a few fans on the case and the front is removed so it can cool down but it still shuts down. What can I do to stop it from overheating.
Many thanks,
Reece
https://linustechtips.com/topic/1213861-overheating/
Best thing you can do is keep the side panel open and get yourself a box fan to blow fresh cool air into the case.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1213861-overheating/#findComment-13753789
And it looks like you did some quick dusting of your PSU shroud before taking the picture. 😂
Make sure your GPU cooler isn't clogged with dust, and make sure the fans for it are spinning up properly.
Is that red card below the GPU blocking a fan? Can it be moved?
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1213861-overheating/#findComment-13753843
I may of taken a picture and seen the dust😂😂. I’ve only just taken apart the card a few days ago and put some new thermal paste on it. The red card is my wireless network card and I’ve brought an pci-e extension cable for it but now I don’t know where to put it. I know the fans work as I stuck my finger in both of them😂😂
https://linustechtips.com/topic/1213861-overheating/#findComment-13753856
You can just move the network card down 1 or 2 (may even 3) slot, and that will give some more clearance for the graphics card's cooling fans.
If the network card is RIGHT up against the fan(s), it will block airflow.
What computer case do you have?
Also, what graphics card is that....do you have the specific model?
( We can see its a Gigabyte RTX card, but WHICH one )
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1213861-overheating/#findComment-13754355
I have brought an extender for the network card so I can move it to the bottom. It’s the Gigabyte RTX 2060 OC edition. The case was one that my friend gave me so I’m not sure what it is but the front is glass so it does restrict a lot of the air flow.
https://linustechtips.com/topic/1213861-overheating/#findComment-13755766
Yeah... that front glass panel WILL restrict airflow...
Are you able to take the front fans off, and mount it back on the INSIDE of the case?
Right now, it is [case] [fans] [glass]
Can you do [fans] [case] [glass] ?
That will give the fans THAT extra 25mm or so extra gap to breathe.
You did mention, even with the front removed, the RTX 2060 still climbs into the 90*C temperature range.
Are you letting the cooling fans on the card run on Auto / Default settings?
Have you tried setting up a custom fan curve?
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1213861-overheating/#findComment-13757290
moving the fans inside the case seems like a good idea but probably won't be possible for the lowest one.
Just an idea like that ... If it doesn't lead to better temps after moving the fans and the network card you could try a negative pressure setup with back and top exhaust only letting the air come in from the unused rear slot under the gpu just like the nzxt h500 does.  I'm not sure if there's enought unuse slot for that to be effective tho and you would have to replace the cover with some mesh cover.  Can be found cheap on amazon.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1213861-overheating/#findComment-13757732
Can you take the glass off? If you can try it out.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1213861-overheating/#findComment-13759261
On 6/24/2020 at 10:57 PM, Famouscooldude said:
Hi guys,
Many thanks,
Reece
Seems like all of your fans are pushing air inside of the case leading to overheating since your PC can't move the hot air outside generated by the CPU and GPU. Just flip the fan on the rear and make sure it pushes air OUTSIDE the case, not INSIDE. Also you can remove the third fan on the front bottom and mount it on to top as exhaust. That will solve your overheating. And that glass on the front panel is very restrictive, but not that bad. Try my solution, you will see that it will at least drop your temps.
CPU: Ryzen 5 5600X - GPU: EVGA RTX 3070 XC3 ULTRA - Motherboard: ASUS ROG STRIX B550-I - Ram: Corsair Vengance LPX 16GB @3200Mhz - CPU Cooler: Noctua NH-L12S - PSU: Corsair SF600 Platinum - SSDs: WD Black SN750 500GB w/ EKWB Heatsink - Case: FormD T1
Laptop: 2020 M1 Macbook Air 8/256
https://linustechtips.com/topic/1213861-overheating/#findComment-13760962
