Hey i reinstalled my audio drivers because i was having issues but now i can't find the Asus Realtek HD audio manager program anywhere. I just reset my PC and still doesnt working, i dont know what to do. I reinstalled Realtek Audio Drivers, but in "C:\Program Files\Realtek\Audio/" i have "Drivers" and "InstallShield", not HDA, etc
https://linustechtips.com/topic/1213839-realtek-hd-audio-manager/
If you are installing Only the Driver, then you go to "device manager" and right click the realtech audio and then click update driver. Select the "Driver" folder you have in the screenshot and windows will install only and just the driver.
If you want the software that comes with it, open the Installshield file and double click the .exe installer to begin the install process.
If the driver fails to work or does not work properly, then get the driver download from the motherboard's website..... which ever that may be.
Hope this helps and good luck!
The .exe on InstallShield wont open idk why
