One easy free way is you can route your pcie cables on top of the GPU
Instead of it going from the bottom
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1213649-card-sag/#findComment-13752073
Just now, Macka09 said:
I have seen that tbh but I didn’t like the thought of putting strain on the sockets on the gpu
Doesn't put that much strain on the socket, my 1060 ran like that with the GPU cables holding it up.
You can use zipties as well or get a minimalistic brace or so .. MSI has a nice RGB one if i'm not mistaken.
CPU: i5 4670k @4.1ghz | GPU: Gigabyte Geforce GTX 1060 G1 Gaming 6GB | MB: Gigabyte Z97P-D3H | RAM: 4x4GB Generic | SSD: Gigabyte 240GB
PSU: Antec High Current Gamer 650 watt | Case: Cougar MX330G
https://linustechtips.com/topic/1213649-card-sag/#findComment-13752091
Try to fit something between the GPU fan-shroud and the case mounting point. A piece of rubber should do the trick. JayzTwoCents also did a video lately talking about fixing sag on the cheap. Maybe check out his channel.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1213649-card-sag/#findComment-13752094
I got that one for my rx590 and it's doing fine.  Ok that card didn't have much sag in the first place but got that bracket anyway.
https://www.amazon.ca/upHere-Graphics-Anodized-Aerospace-Aluminum/dp/B07CM25LF3/ref=sr_1_2?crid=GHK9AHEZ0C46&dchild=1&keywords=uphere+gpu+support&qid=1593007555&sprefix=uphere+gp%2Caps%2C166&sr=8-2
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1213649-card-sag/#findComment-13752604
