Hello everyone! I finally decided to watercool my build after using CLC or heatsink for the last couple of years. My first loop! ^_^
Here is my build, my main computer upgraded all the time :
CPU: AMD FX-8350
MB: Asus Crosshair-V Formula-Z
RAM: Corsair Dominator Platinum (2x4gb)
GPU: MSI R7950 Twin Frozr III OC (v1)
SSD / HDD : 64gb Crucial M4 + 1,5Tb of Caviar Blue
PSU: Corsair HX650 (v1)
Case: Fractal Design Arc Midi R2
Watercooling (thanks DazMode!):
XSPC Raystorm (AMD) XSPC EX240 + EX240 CrossFlow
XSPC D5 Tank XSPC 3/8 - 5/8
Black tubbing
Feser black fittings (x6) +
XSPC Black chrome fitting + Bitspower 90-degree fitting DazMode D5 Vario (Laing D5)
Here are much better pictures of the rig, not a lot since I'll be changing all the LED to red and adding a GPU block soon!
Here's how the lighting looks like
Socket area (Raystorm AMD block); note how that acrylic bracket bends under the pressure  :huh:
Inside!
Everyone (maybe not) favorite fans, the Gentle Typhoon 1850rpm!
On my desk!
As I said, more is to come as I will install the GPU block (an EK-FC7950 Acetal + Backplate) and switch all the LED (+ Corsair's fan) to red
Intel Core i7-5820k @ 4,6Ghz; Asus X99 Deluxe; GSkill Ripjaws 4 (4x4) 2400Mhz; MSi GTX 980 Reference @ 1.4Ghz; CM V700; Phanteks Enthoo Luxe; Windows 8.1 Pro
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/
Looks like it will be a nice first loop that you can add to in the future. You just going to cool the cpu for now or are you going to add in a video card to cool to?
Thank you!
Yes, expanding is the plan: I'll add the a GPU and a NB / MB block later (maybe when I clean the loop in ~6 months).
But, I want to try a loop first ( and reconsider it if I destroy my computer  :P ).
Also, my 7950 don't have a 7970 PCB (first revision of TF3), which mean the only block that will fit are sold only in the US (importing fees $$$)  :(
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/#findComment-132336
You can resize pictures easily online, try this site> http://www.picresize.com/
Then what I do is upload the images I want to use to Photobucket (it's free to join) then just copy/paste the IMG code like so.........
Pic size is now 900x675 25% smaller.
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/#findComment-132445
Oh, nice, thanks!
It looks very cool, I love the red and black sleeved power connectors, did you custom sleeve them yourself?
I wish I was that good  ;)
It's BitFenix Alchemy extension; got this "starter" kit from Performances-PCs
UPDATE, testing leak (don't be fooled, those are pure-white LED)!
Oh, and nothing is powered on, I just unplugged the extensions from behind  :P
(Preparing to fill)
(Leak testing!)
(Are those "white" bubbles normal?)
Surprised on how smooth it went ( for now ^_^  )
I think I broke my pump speed control  :unsure:
Otherwise the loop is going strong; a night of leaking test wont hurt though and the res is way cleaner  ^_^
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/#findComment-132977
Shameless bump as my build is now finished, how does it look?  ^_^
(crap photo are in the first post)
I'm going in the 1,53V for the 5Ghz! Not a golden FX, but a custom loop don't seem to care.
Temps are awesome.
I did forgot to remove the plastic lid on the block at first though... that overheating was not normal  :P
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/#findComment-138462
Pretty decent job, Your the first person I've seen that's put a rad in the front and moved the drive cage back to the other holes. I would like to have seen the gpu included in the loop and a red themed psu, but that's just nitpicking
Thanks!
I know, with a GPU block I would've been able to take other thing than an EX240 CrossFlow and push/pull the normal EX240 and make a much cleaner loop ^_^
Sadly I can't find any 7950 pcb block (early adopter of the 7950s I guess...) in Canada, the only one that would work are Swiftech Komodo 7950 and EK-FC7950 :(
But, maybe in next few months I'll be able to find / import one!
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/#findComment-141342
I love fractal design cases with water cooling. Nice build  :)
My Rig:
Case: NZXT H210 CPU: AMD Ryzen 7 3700x  Motherboard:  MSI B450 AM4 Motherboard  Memory: GeIL EVO POTENZA 16GB Video Card: MSI RX480 Power Supply: Corsair TX 750w Storage: Samsung 840 120GB And a 500GB WD BLUE Monitor: Acer S231HLbid 23" and an old Dell Mouse: RAZER DeathAdder 3.5G Keyboard: Ducky DK9008G2 PRO MX Cherry Blue
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/#findComment-145563
  • 3 weeks later...
So, I finally found a new camera (Sony Alpha SLT-A37) and took some photos of the rig (not crappy one). I didn't upload that manny pictures as this loop will soon have a GPU block inside, switching the CrossFlow EX240 to a normal one and making everything Red / Black (getting rid of the white LED + corsair white rings on the fan).
The GPU block will be an EK-FC7950 Acetal that is comming from the US, so maybe I'll be able to post the final build next week!
Thank for the suggestions!
Thank you, I didn't knew the company before and I must say, awesome cases.
https://linustechtips.com/topic/12130-arc-midi-fx-first-loop/#findComment-235356
