So i got a question.
I had a be quiet! Dark Rock 4 Pro, the temps of my CPU were like 35-45°C idle and almost 100°C at full load on Prime95, blend and custom(in-place). I upgraded to a Water cooler, a Z73 Kraken. Now im getting idle temps anywhere about 32-40°C but still have got full load temps of about 92°C on Prime95, even though i have got a water cooler now. I already tried to change the thermal paste, no changes in temps. Isn't that a bit too hot, even though i overclocked the CPU a bit? What are normal temps with a AIO water cooler? I also used 2 different monitoring softwares to make sure the temps were displayed right. (HWMonitor, Coretemp)
AVX2 and AVX were enabled at Prime95 torture test.
Hardware
CPU: Core i7 8700K (Overclocked to 4,8Ghz w/ 1.270V vcore)
Cooler: NZXT Z73 360mm AIO Water Cooler
RAM: 2 x 8GB Corsair Vengeance lpx 2666 mhz(dual-channel, XMP enabled)
Mainboard: Z370 Gaming Pro Carbon (MSI)
https://linustechtips.com/topic/1212866-normal-aio-cooler-temps/
100º is where intel cpus thermal throttle (iirc) so you're probably getting better actual performance now that you're keeping it under that. But large AIOs like that are only a bit better at cooling than the top tier air coolers, and the 8700k is a top notch space heater.
You might consider a delid, even using quality paste and using the socket retention system to hold the ihs down (silicone gasket intel uses creates more of a gap, more gap=worse cooling) you should see a significant improvement (you don't have to use liquid metal for a delid, but as Steve showed it can be a huge difference)
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
What is your ambient temp?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
2 hours ago, Deffet said:
What case do you have? Radiator placement matters alot. I just switched my 360 rad from top to bottom in my lian li pc-011 dynamic and temps went down like 20 degrees on my 7700k. The gpu was heating up the radiator earlier
i got a 570X Corsair, its attached at the side of it, a 360mm. Its attached like this:
First the fans, then the radiator (fans blowing air inside)
  • 6 months later...
Hardware
I know you posted this a few months back, and it may or may not be relevant anymore to your situation, but for others who come across this thread, it may help them. From what I could tell, upon looking up your case design, you should be able to implement a "Push/Pull" fan setup, with your 360mm radiator. That will help cool your processor down, (possibly) immensely. Meaning you need to install/have, based on your case design, 3 fans in front of the radiator, which is likely how it is already setup, pushing the air through the radiator, then the radiator itself, then 3 more fans on the other side, pulling the air from the other fans and radiator. That is one of a couple of things you can do to help keep your 8700k cooler, at both idle, and especially under load. I would also de-lid your AIO pump from the processor, and clean off both your copper plate, and the processor, of any thermal paste you previously used (if you buy the Thermal Grizzly Kit, it comes with alcohol pads to clean off your old paste), and replace it with liquid metal (https://www.amazon.com/dp/B078J4PSHM?psc=1&ref=ppx_pop_dt_b_asin_image). It's riskier to use, but the payoff is much more worth it, because it keeps your CPU cooler, by a few degrees Celsius, especially under extreme load. Lots of amazing reviews and great video's on how to apply this stuff to both the processor and AIO pump copper plate, using the applicator and Japanese black Q-tips (provided in kit). Just make sure you don't put too much, and don't let it touch anything aluminum, as it will eat through it, causing bad pitting, and possibly a chemical reaction, if water gets on it, while it's touching the aluminum. You do need to apply a bit of pressure with the q-tip, while holding it as vertical as possible, to spread around the liquid metal properly. I have seen reports of idle temps for example going from 50 to 60 degrees Celsius down to high 20's to low 30's degrees Celsius, using this product, and I can personally affirm this, because it happened for me as well. It's one of the best thermal metals on the market.
As a side note I almost bought the Kraken X73, but chose instead to get the MSI MAG CORELIQUID 360R instead.
Second thing you can do to keep your computer cooler, is HOW you overclocked your CPU. I run my computer at 4.6GHz on all 8 cores (could go higher easily, but I chose to keep it lower), plus turbo boost up to 5GHz. I changed my multiplier for the CPU and North Bridge (from 100 to about 106) to x46 instead of the stock x36, and let the MB automatically control the voltages, instead of manually increasing the Vcore. Changing the voltages on the Vcore, can help stability in certain situations, but dramatically increases the running temperatures, especially on an already furnace of a CPU. You may have to play around with your multipliers and settings, until you figure out the proper combination, but keep your Vcore voltage either on automatic, or as low as stably possible. I also overclocked my RAM, while keeping the voltages lower as well. Everything is extremely stable, and I run 40 to 50 degrees Celsius cooler, doing it this way, than it did before by just turning up the Vcore voltage. I was hitting the thermal throttle all the time before, and the CPU not only was running hot, but was heating up my room like a heater, and heating up my GPU, causing it to throttle back as well, because the air temp was getting so hot. Now everything runs cool (Max average is now 50 to 55 degrees Celsius compared to before which was 90 to 110 degrees Celsius).
Hope this helps you a bit, and I can help you with any other questions you may have, or links to things if you need. I've am an electronics expert, and have been building and fixing computers for over 30 years, and was an Electronics Technician in the Navy.
Hardware:
CPU: Core i7 9700K (Overclocked to 4.6GHz)
Cooler: MSI MAG CORELIQUID 360R - AIO RGB CPU Liquid Cooler
RAM: Corsair Vengeance LPX 32GB (2x16GB) 3200MHz C16 DDR4 DRAM Memory Kit – Black (Overclocked to 3800MHz)
Mainboard: ASUS Prime Z370-P II
GPU: PNY NVIDIA RTX 2080ti with Blower
