So I have an asus rtx 2070 super 8gb, and today is a "hot" day. and I've noticed the idle temps are around 50 or 51degrees, is this normal and fine??
On some colder days the idle temps are around 40 or 35 but mostly 40 plus, So I was just wondering if there is nothing to worry about.
https://linustechtips.com/topic/1212757-gpu-idle-temps/
Considering the fans on it are most likely not spinning, it's normal.
You can make a custom fan curve in MSI Afterburner if you don't want it idling at 50C. Either way it won't damage it or anything, so there's nothing to worry about.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1212757-gpu-idle-temps/#findComment-13745223
Yes it is
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1212757-gpu-idle-temps/#findComment-13745231
