X470 red led error
Go to solution Solved by Ozen_Z,
2 hours ago, Eighjan said:
That says, to me, overheating... somewhere.
Thanks for feedback the gpu was the problem
My pc was working fine for over a year.
Then someday I tried to boot the pc the cpu fan was running and the rgb,but there were two led lights were alternating with no post at all on the display. I restarted many times until it booted found out that was smth with bios reseted them with cmos battery worked for 2 weeks but the problem didn't stop.
I don't how to explain it ,when I shut off my pc and immediatley boot it up it gives me the same error,but if I let it rest for 10 mins after shutting it down it boots with no errors or cycles.So I just let the pc on until I sleep and booted again then another problem I encountered. I booted the pc worked for an hour then no display and the monitor tells me no signal but I can hear the sound from my headset ,it was the drivers for the gpu reinstalled them with ddu and a clean installion worked for a day but again the same thing. The real problem is now when I boot there is a 4th led on the bottom left corner that lights up and no post any idea to fix this issue
Sry for my bad english and poor knowledge about tech
My specs:
Amd ryzen 2700x
Rtx 2060
Corsair lpx 3000mhz cl16
X470 gigabyte aorus ultra gaming
Psu gigabyte 750w gold
Hdd m.2 samsung evo 970 500gb
Seagate fire barracuda 2 tb
https://linustechtips.com/topic/1212087-x470-red-led-error/
Sounds like some kind of overheating... check the graphics card fans.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1212087-x470-red-led-error/#findComment-13740246
The problem now is when I power on the pc the fourth led on the bottom left solid red with no flickering and the cpu fans turn on and case fans but no post at all or bios
https://linustechtips.com/topic/1212087-x470-red-led-error/#findComment-13740296
What label does that LED have?
EDIT:
VGA... remove and re-seat the graphics card.
WHY NOT...?!
https://linustechtips.com/topic/1212087-x470-red-led-error/#findComment-13740305
If the VGA POST LED is still on, then I'm out of options, sadly...
WHY NOT...?!
https://linustechtips.com/topic/1212087-x470-red-led-error/#findComment-13740348
WHY NOT...?!
https://linustechtips.com/topic/1212087-x470-red-led-error/#findComment-13740355
  • 3 years later...
