Hello everyone! Sorry if this isn't the correct thread for my post, but I'm looking for some advice. I want to restore an old Acer Aspire 5315-2847, which has
-Intel Celeron M 560
-120 GB HDD
-512 MB RAM (Yep)
I installed 2 GB of RAM and the computer was suddenly usable (It had Windows XP and it was completely useless).
I installed windows 10 and it actually works pretty well! Just one problem... The video chip doesn't have updated drivers, so the screen resolution sucks (It has a 1280x800 screen, but I can only use 1024x768 or 800x600 resolution).
According to DXDIAG, the graphics chip is Intel's "GM965/PM965/GL960", and the label on the laptop says it's a X3100 accelerator.
I was wondering if anyone knows if there's a way to fix that, any kind of third party software that circumvents this problem, or any way to adapt the older drivers to Windows 10, thanks everyone!
EDIT: If there's no solution, I can always install Windows 7, but since it's running out of support soon (If it didn't already), I much rather it have win10
https://linustechtips.com/topic/1211969-reviving-an-old-laptop-graphics-problems/
Can you find a Windows XP driver, or a Windows 7 driver for it? You might be able to install it in Windows 10. Probably not though.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
make sure the memory is compatible with your chip
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
11 minutes ago, ivan3dx said:
I wasn't aware of this. RAM SODIMMS can be incompatible with video chips?
sorry didnt read your full post. Try installing linux
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
4 minutes ago, ivan3dx said:
Not an option, I already thought of that but the computer is meant for an older lady that's used to Windows
try this. I looked up your chip and found this intel driver site. https://downloadcenter.intel.com/product/81508/Graphics-Drivers-for-Mobile-Intel-965-Express-Chipset-Family Note that there IS no windows 10 support. If you want a third party driver you are gonna have to dig real deep. would be more janky than your average "did i get scammed" ltt video
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Yep, I tried this just like half an hour ago. It was installing and then the screen went black, but you could tell it was still backlit. Then, a cursor appeared and it was much sharper looking, which makes me think it was the correct resolution. However, it didn't go back to Windows desktop. I'm letting it sit for a while, I don't know if it's still installing or if the driver simply doesn't work. I'll go back to it in a while and check if the driver works. If it doesn't, I'll just install Windows 7
windows 7 seems like the only choice for this display. Unless you want to spend the time and take the risk of finding and downloading any hacked drivers
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
It worked! I installed the Windows 7 driver and it works on Windows 10 too! Thanks man, it helped a lot. You helped me make 10 bucks lol
godspeed! enjoy your 10 bucks!
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
