Budget (including currency): around 1500 EUR / 1700 USD
Country: Austria (EU)
Games, programs or workloads that it will be used for: ArchiCAD, AutoCAD, Autodesk Inventor, Cinema 4D... LOTS of rendering!!
I'm currently looking for a new workstation pc for CAD, rendering and engineering stuff. I need good rendering performance and the pc needs to be quiet as it's gonna be rendering over night in the same room I'm sleeping. Good looks are a plus!
I attached my pcpartpicker list, what do you guys think?
https://linustechtips.com/topic/1211647-cad-workstation-pc/
3700x will be a better bet. twice the threads at similar per thread performance. I would suggest a large air cooler like the NHD-15, DRP4 or the H100i instead as the h100x is known to get pretty loud. the i and x versions are very different.
you could use 32gb of ram, it will be nice in cad.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1211647-cad-workstation-pc/#findComment-13737059
34 minutes ago, muehli said:
This is my suggestion:
Few things to note:
- You mention about leaving to render over night so I believe you will benefit more from the multi-threaded prowess of Ryzen, instead of the single threaded speed of intel. It's also much better value with better upgrade options and features.
-Cooler: I went for an air cooler which should perform great and be very quiet. If you get the chromax version it will look much nicer. However an AIO will be slightly quieter if you'd rather that route
-The Samsung drive you picked is a great performer, but not great value. If you want value get the P1 that I listed which give syou double the capacity. If you want speed, you may as well go for pcie 4.0 which will give you incredible performance. The Corsair drive listed costs the same as the crucial drive.
- I don't know how much your workflow benefits from a GPU, but the 5600xt is a great midrange option, and will game great if you ever feel like it.
-P400A is a great value and airflow focused case, but obviously you may want a different one based on aesthetics or noise levels. Maybe look at bequiet cases for quiet options. Your case fan choice will also impact noise levels alot
Hope this isn't too much info, and hope it helps :)
Edit: Just saw your comment on RAM. Use the ~€70 and maybe get an AIO or a better GPU then
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1211647-cad-workstation-pc/#findComment-13737110
Few things to note:
Thank you!
The case is just personal preference, I know that it's expensive but the 280X just looks so nice... I'll stick to the Amd 3800X as the Cinema 4D rendering engine only uses one core and for general CAD work 8 cores are more than enough. How much worse is the 5600XT to the 5700XT?
https://linustechtips.com/topic/1211647-cad-workstation-pc/#findComment-13737146
46 minutes ago, muehli said:
Thank you!
Sounds good. Tbh your selection looks better than mine. 5700XT will give you a noticeable improvement over the 5600XT and I would strongly recommend it. With the 3800X you may want to wait for the 3800XT to be launched on July 7th. It will have slightly higher clocks than the current model.
Also, that case does look great :)
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1211647-cad-workstation-pc/#findComment-13737272
