Argb strip question
Go to solution Solved by thrasher_565,
7 hours ago, emilyadella said:
Okay so I have non rgb ram with heatspeaders, I do not want to remove the the heat spread as it is ballistixs. I do want to want to turn it into argb ram by 3D printing some translucent led holders and if it works do the same for fan grills.
on that note what I want to know is can you custom trim argb strips and what is involved.
also one last thing is it possible to add custom parts to Corsair node pro etc..., I know with an adapter you can attach them but you are at the mercy of matching there leds to yours so far it has worked ok but I would rather just make my own parts to add to the drop down to get it perfect.
ya you can do just that. side note is corsair ram cooler has an rgb strip that just points in to clear 50mm fans and has a box around it.
you can cut argb strips so ling as it has the copper pads on both sides. you can also just buy signal smd named dots. more info can be found in my sig on rgb links.
hears a link to my guide on corsair pin out and others
https://linustechtips.com/topic/1211234-argb-strip-question/
Edited by thrasher_565
https://linustechtips.com/topic/1211234-argb-strip-question/#findComment-13734759
okay cant find those on any argb strigs only regular rgb, do you know how to or if these can be cut to length https://www.newegg.com/airgoo-amdrgb0001-rainbow-2-strips-fit-for-3-pin-5v/p/1W8-011Z-00004?Description=addressable rgb strip&cm_re=addressable_rgb_strip-_-9SIAKRYB740142-_-Product&quicklink=truehttps://www.newegg.com/airgoo-amdrgb0001-rainbow-2-strips-fit-for-3-pin-5v/p/1W8-011Z-00004?Description=addressable rgb strip&cm_re=addressable_rgb_strip-_-9SIAKRYB740142-_-Product&quicklink=true
https://linustechtips.com/topic/1211234-argb-strip-question/#findComment-13736396
9 hours ago, emilyadella said:
don't no i would just buy a strip that you no has it.... instead of gambling
oh i just posted the pic to show you were to cut. the argb strip will have 3 wires insted of 4 and will be 5v di/do and ground
https://linustechtips.com/topic/1211234-argb-strip-question/#findComment-13737936
55 minutes ago, emilyadella said:
I mean to the strip with those pads because none of the aRGB strips that I have found have them
link
link
keep in mind that do to the virus lots of stuff is not being posted and what is posted the price went up....
https://linustechtips.com/topic/1211234-argb-strip-question/#findComment-13739425
