MoBo form factor & case questions
Solved by Hairless Monkey Boy,
5 minutes ago, CarlCarl said:- Will i loose out on features with a high-end mATX?
Vs ATX you will lose only a few expansion slots.
6 minutes ago, CarlCarl said:- Can i get a good overclock with a mATX board?
Yes, depending on the exact board of course.
6 minutes ago, CarlCarl said:- Is it better to go for a small ATX case?
Define better. If you want a small PC and don't need the extra expansion, it would be better to do mATX, than to cram an ATX system into a too-small case.
7 minutes ago, CarlCarl said:- Can a mATX or small ATX case provide airflow sutable for overclocking(GPU & CPU)?
Same size case, the mATX one would probably have better cooling. Depends on the exact case.
