gtx 970 temps
Go to solution Solved by Haro,
On the higher side but totally fine
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1210643-gtx-970-temps/#findComment-13728442
Just now, pniok said:
what should be the highest temp i can reach and be fine?
Tj temps for any gpu is typically around 95 and above
But anything Below 90 is good
Build Log:
https://linustechtips.com/topic/1210643-gtx-970-temps/#findComment-13728508
