So I’ve been build a pc and it’s not turning on, I have a 9900k and a Gigabyte Z390 Aorus Pro Motherboard but a little light in the bottom right of the board is flashing indicating it’s because of the cpu, idk where else to go to ask for help
https://linustechtips.com/topic/1210543-help/
1 minute ago, DFA45 said:
Well I’ve checked everything, could it be the cpu is dead?
Check any bent pins
Re seat the cpu
Clear the cmos
Make sure the PSU is plugged and turned on
Check for any debug led
Try with one stick at a time
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1210543-help/#findComment-13727825
Just now, DFA45 said:
Cmos?
The cmos battery
Build Log:
https://linustechtips.com/topic/1210543-help/#findComment-13727876
