Need help.
Go to solution Solved by Jurrunio,
4 minutes ago, xXFitzXx said:
on amazon it says the spire comes with ryzen 7
Cooler compatibility depends on socket, not CPU
Does the Wraith Spire cooler work with the Ryzen 5 3600, B450 TOMAHAWK MAX, and Gskill TridentZ RGB?
https://www.lttstore.com/
1990 M3s are the best looking things ever made.
^This statement has been retracted^
2020/2021 BMW S1000RRs/Ninja H2s are the best looking things ever made.
Don't ask to ask.
If you want me to see the reply, @XGoodGuyFitz(aka me) and/or quote me.
Thanks!
https://linustechtips.com/topic/1210287-need-help/
work? yes
Desktop benching:
https://linustechtips.com/topic/1210287-need-help/#findComment-13725593
Just now, Jurrunio said:
work? yes
So it will fit with no problems
Don't ask to ask.
Thanks!
https://linustechtips.com/topic/1210287-need-help/#findComment-13725595
Does the wraith stealth/spire  come with the 3600 so why wouldn't it work
CPU: Ryzen 5 3600
GPU: Gigabyte gtx 1660 Super oc 6g
Mobo:MSI b450 tomahawk max
RAM: 32gb ddr4 lpx vengeance 3200mhz
Storage: WD sn550 1tb, Baracuda 2TB HDD (*In use), Hitachi 2tb HDD, WD 0.5tb HDD (both HDD knackered)
PSU: cxm 450
Case: Corsair Carbide Series
https://linustechtips.com/topic/1210287-need-help/#findComment-13725617
Don't ask to ask.
Thanks!
https://linustechtips.com/topic/1210287-need-help/#findComment-13725622
Unless the computer case get in the way, yes
Desktop benching:
https://linustechtips.com/topic/1210287-need-help/#findComment-13725626
Desktop benching:
https://linustechtips.com/topic/1210287-need-help/#findComment-13725629
ok thanks.
Don't ask to ask.
Thanks!
https://linustechtips.com/topic/1210287-need-help/#findComment-13725630
oh. is socket like, am4 or what
Don't ask to ask.
Thanks!
https://linustechtips.com/topic/1210287-need-help/#findComment-13725632
Yeah that standard issue for the newer amd motherboards
CPU: Ryzen 5 3600
PSU: cxm 450
https://linustechtips.com/topic/1210287-need-help/#findComment-13725639
oh ok. thx for help.
Don't ask to ask.
Thanks!
https://linustechtips.com/topic/1210287-need-help/#findComment-13725641
Yes, AM4 is the socket for AMD desktop chips. For intel you have LGA 1152 and the new 1200
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1210287-need-help/#findComment-13725644
For intel also one of the standard chips is LGA 1151
CPU: Ryzen 5 3600
PSU: cxm 450
https://linustechtips.com/topic/1210287-need-help/#findComment-13725647
