Desktop benching:
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725306
Just now, Electronics Wizardy said:
budget?
capacity?
ALso don't look at dram alone, there are many good drives without dram, and bad drives with, look at the total package.
https://mdcomputers.in/adata-xpg-gammix-s5-256gb-m-2-agammixs5-256gt-c.html?sort=p.price&order=ASC
https://mdcomputers.in/adata-xpg-gammix-s11-pro-256gb-m-2-agammixs11p-256gt-c.html?sort=p.price&order=ASC
budget is on the low side, 55$
i linked three.. can u check n tell me if these have dram or not..
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725314
2 minutes ago, Mahbub said:
Adata's fallure rate is higher than average, and you shouldnt buy NVMe at low budgets. They just arent faster in the real world than the better bunch of SATA SSDs
Desktop benching:
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725324
1 minute ago, Mahbub said:
The first 2 seems to be the same
Also there is a lot more to a drive than dram, whats your use case?
The first one is a pretty budget drive, no dram, and slow ish speeds.
For that price, how about this drive?
https://mdcomputers.in/samsung-860-evo-250gb-m-2-mz-n6e250bw.html?sort=p.price&order=ASC
this is sata, but good brand, and about the same speed in most uses
Or get something like a 500gb mx500, the extra space is nice.
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725332
my use case is only windows 10 installation.. boot drive.. and okk sot first one i wont get,, hw abt the second two?also the samsung one is sata. the issue is if i buy sata it eill disable my sata ports on my mobo.. and i am using all mobo sata ports so i have to go with nvme..
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725364
so like it seems i should drop the idea of m.2? i have a samsung 850 evo sata as boot drive.. was thinking to change it to game storage and use a cheap nvme as boot drive
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725371
what motherbord do you have? Normally they only disable one or two other ports.
What is the full build?
Can you use a 2.5 in sata drive?
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725372
Id probably just add anouther game drive, and keep your current boot drive. there won't be much of a performance improvement.
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725375
my mobo is z370m d3h gigabyte.. the issue is. i have total 6 sata ports 4 on top 2 below gpu.. i have two 250gb samsung 850 evo.. one 1 tb wd blue, one 2 tb wd blue and one 1tb wd black .. so 5 of my sata ports r being used, now one of the sata ports is pretty much covered by my 3 slot gtx 1080 amp extreme. after checking the mobo manual.. i found if i put a sara m.2 it will disable one sata port from top... which i cant allow to happen as i cant use the other one as thats coverd by gpu.. now i transferred a game from wd black to one 850 evo.. lod times much better now.. so thought to make both the sata ssds as game drives n use a nvme as boot drive.. so that the whole story.
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725406
COuld you replacae one of the smaller saata drive with a bigger one? Like get a 1tb sata ssd to replace a 250gb?
but if you want a boot nvme, it doesn't really matter, the cheap s5 will be plenty fast for a boot drive, you don't seem to need much io for your boot drive here.
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725424
Thanks to the 3 slot card. One sata port is gone.. or else I would have bought a sata ssd like 500 gb n put it..
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725427
also you can get angled sata cables that should fit under your gpu.
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725430
Thought of that too.. but the top sata port is literally being sandwiched..  nothing can get in there unless it's a two slot card .
Also i made a mistake.. i actually have a crucial 480gb.and a samsung 250 gb.. i replaced the other 250 to my laptop and bought in the laptop 480 to the pc...as for the replacing the samsung 250 which is my boot drive with a 1tb .. yes. But samsung 1tb evo is expensive
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725442
M.2 saves cable management effort, that's it. As boot drive SATA and NVMe feel exactly the same.
Desktop benching:
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725478
yes and i wanna make the 250gb sata ssd as a gaming drive... and as u have seen from previous comments i cant put a sata ssd or use another sata ssd,, all usable sata ports used up.. and if i put a sata m.2 it will disable one of my hdds,, so now my only option is a cheap 240gb nvme as a boot drive if i wanna convert the 250 gb sata to game drive.. btw u said adata has high failure rates..how is this one?
https://mdcomputers.in/galax-gamer-240gb-m.2-bina1m4t6bg28bnlbyxwxn.html?sort=p.price&order=ASC this is cheaper than the adata one.. but is galax good? also this one has pcie 3.0*2 channel instead of pcie 3.0*4 channel in the adata one, what does that mean? will this galax one be slower?
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725494
Yes the galax drive will be slower
and tbh if you're such a storage hog, save up for a bigger drive altogether. Even HDD, to put all the stuff that doesnt care about speed
Desktop benching:
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725576
Yes i have enough hdd.. just need more ssd space for ganes i regularly play. And thanks for helping me out
https://linustechtips.com/topic/1210259-ssd-with-dram-help/#findComment-13725645
