System spec:- intel i5 8400, gigabyte B360M D3H-CF, g skill 8gig 2400mhz 1 stick, 550 wat power supply,1660 super msi, now the problem is GTA giving me 30 fps on ultra 1080p but it was supposed to go more than 100 fps same with far cry new dawn gating 50 to 60 and some time frozen for seconds  some other AAA title run at 15 to 30  fps any fix for this
https://linustechtips.com/topic/1210242-need-help-with-1660-super/
Ddu
Check temps
Make sure your not page filing
Phone: Pixel 3a (Purple-ish).
Build Log:
29 minutes ago, Dishonored said:
constant when playing game's but the problem remain
Build Log:
