Help For a virtual machine
Go to solution Solved by KaiLikesLinux,
Keep a link to the ISO in a folder, as in the link to where it is on the computer. Makes it easy to find and if needed. Also keep an external drive of them if possible. These are tricks I learned when mastering VirtBox
4 minutes ago, Berkomeister said:
https://rufus.ie/ download this and make your files into a bootable iso.
Rufus doesn't make ISOs, it uses them.
2 hours ago, YourRandomForumGuy said:
but when i downloaded it i am unable to find the iso instead it is a folder
You seem to have extracted the files from the ISO. Redownload it and don't extract the files.
