Posted June 15, 2020 Do you prefer one big ol monitor or 2 normal monitors (27")? Non-curve only! For gaming and photo/video editing PC SPECS AMD Ryzen 9 3900X Asus Prime X570-P 32GB DDR4 (4x8GB) 3600MHz NVIDIA GeForce RTX 2080 Super 8GB GDDR6 1TB M.2 NVMe PCIe 2TB 7200RPM 256MB Cache SATA III 6Gb/s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 15, 2020 2 regular monitors. One for fullscreen/borderless window gaming, and a secondary for web/media/discord/etc. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 15, 2020 Just for gaming would probably be the ultra wide, but if you're also intending to do work on it or multi tasking in any way I think that two regular monitors would be better. PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular - Case: Corsair Obsidian 450D - OS: Windows 7 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 15, 2020 Author Just now, TomvanWijnen said: Just for gaming would probably be the ultra wide, but if you're also intending to do work on it or multi tasking in any way I think that two regular monitors would be better. I'll edit my post, the PC is combo work/gaming! PC SPECS AMD Ryzen 9 3900X Asus Prime X570-P 32GB DDR4 (4x8GB) 3600MHz NVIDIA GeForce RTX 2080 Super 8GB GDDR6 1TB M.2 NVMe PCIe 2TB 7200RPM 256MB Cache SATA III 6Gb/s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 15, 2020 I used to have a Triple Wide 27" setup, but then I got a 34" UWQHD, and while not having a side monitor can sometimes suck, the Ultra wide still blows it out of the water. Gaming Build: CPU: Ryzen 7 3800x | GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) | Motherboard: Asus X570 TUF GAMING-PLUS | RAM: G.Skill Ripjaws DDR4 3600MHz 16GB | PSU: Corsair RM850x | Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo | Cooler: Corsair H115i Pro XT | Case: Lian Li PC-O11 Peripherals: Monitor: LG 34GK950F | Sound: Sennheiser HD 598 | Mic: Blue Yeti | Keyboard: Corsair K95 RGB Platinum | Mouse: Logitech G502 Laptop: Asus ROG Zephryus G15 Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz NAS: QNAP TS-451 6TB Ironwolf Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 15, 2020 Author 1 minute ago, Statik said: I used to have a Triple Wide 27" setup, but then I got a 34" UWQHD, and while not having a side monitor can sometimes suck, the Ultra wide still blows it out of the water. sounds like you're saying I should just do an ultrawide with an additional monitor on the side LOL PC SPECS AMD Ryzen 9 3900X Asus Prime X570-P 32GB DDR4 (4x8GB) 3600MHz NVIDIA GeForce RTX 2080 Super 8GB GDDR6 1TB M.2 NVMe PCIe 2TB 7200RPM 256MB Cache SATA III 6Gb/s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 16, 2020 1 hour ago, cmcman21 said: sounds like you're saying I should just do an ultrawide with an additional monitor on the side LOL Literally this. Gaming Build: CPU: Ryzen 7 3800x | GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) | Motherboard: Asus X570 TUF GAMING-PLUS | RAM: G.Skill Ripjaws DDR4 3600MHz 16GB | PSU: Corsair RM850x | Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo | Cooler: Corsair H115i Pro XT | Case: Lian Li PC-O11 Peripherals: Monitor: LG 34GK950F | Sound: Sennheiser HD 598 | Mic: Blue Yeti | Keyboard: Corsair K95 RGB Platinum | Mouse: Logitech G502 Laptop: Asus ROG Zephryus G15 Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz NAS: QNAP TS-451 6TB Ironwolf Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 16, 2020 5 minutes ago, cmcman21 said: sounds like you're saying I should just do an ultrawide with an additional monitor on the side LOL Well, yes, that would be the best of both worlds. I would say it depends on personal preference. I prefer having proper borders between different screens, while others like everything to blend into each other. Think for yourself what you like. Either way, I've heard that gaming on ultrawides is great, so if you fancy improving that experience, I think that ultrawide + regular could indeed be a good option. PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular - Case: Corsair Obsidian 450D - OS: Windows 7 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 16, 2020 Author 4 minutes ago, Statik said: Literally this. Me at the end of all this PC SPECS AMD Ryzen 9 3900X Asus Prime X570-P 32GB DDR4 (4x8GB) 3600MHz NVIDIA GeForce RTX 2080 Super 8GB GDDR6 1TB M.2 NVMe PCIe 2TB 7200RPM 256MB Cache SATA III 6Gb/s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 16, 2020 1 hour ago, cmcman21 said: Me at the end of all this I would VESA stand a monitor ontop of my UW. I would only put one beside it if it was mounted vertical. But yes, you're correct. Gaming Build: CPU: Ryzen 7 3800x | GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) | Motherboard: Asus X570 TUF GAMING-PLUS | RAM: G.Skill Ripjaws DDR4 3600MHz 16GB | PSU: Corsair RM850x | Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo | Cooler: Corsair H115i Pro XT | Case: Lian Li PC-O11 Peripherals: Monitor: LG 34GK950F | Sound: Sennheiser HD 598 | Mic: Blue Yeti | Keyboard: Corsair K95 RGB Platinum | Mouse: Logitech G502 Laptop: Asus ROG Zephryus G15 Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz NAS: QNAP TS-451 6TB Ironwolf Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 16, 2020 I'd moved from 3x 24" 1200P monitors to a single 34" UW monitor years back and haven't looked back, but my usage scenario is basically gaming and watching movies....2.35:1 movies cropped to fill entire 21:9 screen is da shizz. I've another setup with a 32:9 monitor (only 3840x1080, there's a newer version with 5120x1440 res) that is plain awesome for gaming (for games that allows for 32:9 format). ut, having a 21:9 34" monitor AND a smaller 24" 16:9 monitor for workstation use might be better and less expensive alternative. Main Rig: AMD AM4 R9 5900X (12C/24T) + Tt Water 3.0 ARGB 360 AIO | Gigabyte X570 Aorus Xtreme | 2x 16GB Corsair Vengeance DDR4 3600C16 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Topre Type Heaven + Seenda Ergonomic W/L Vertical Mouse + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2 2nd Rig: AMD AM4 R9 3900X + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 | 2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Keychron K2 + Logitech G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
