Fan going slow, why?
Is it a slower fan? What's it hooked upto (Assuming Motherboard), do you have it set slower, are they all the same type of fan?
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/120960-fan-going-slow-why/#findComment-1610540
Its connected to your motherboard? Its probably that slow because system is cool, so it spins slower....
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/120960-fan-going-slow-why/#findComment-1610541
Off topic: Have you done a build log on your machine? Wanna see your stacker build :D
https://linustechtips.com/topic/120960-fan-going-slow-why/#findComment-1610552
Indeed, I have better pictures coming soon (thanks for the reminder), I'll try to update it today...
http://linustechtips.com/main/topic/102974-haf-stacker/
@Mixzzz
https://linustechtips.com/topic/120960-fan-going-slow-why/#findComment-1610561
