Hey, I have to come to this forum because I am convinced that my computer is seriously messed up. I have a gtx 1080, i5 7500, 8gb ram, an ssd, and an hdd. At first I was convinced that my downward trend in game performance was attributed due to my cpu, however today I was trying to run valorant on high settings and I couldn't even maintain a constant 60 fps. After this I was convinced something was wrong and tried to play warzone and couldnt even maintain 60 fps in the menus. I ran a userbenchmark and was told that my ssd was in the 0th percentile and should check if it was plugged in. After this, I replugged my ssd ran multiple virus checks to no avail and am now really scared for the state of my pc. If anyone can reply that would be much appreciated, and if you would like to call and help that would be awesome as well!
https://linustechtips.com/topic/1209070-need-help-immediately/
Umm sounds serious. What psu are you using? Also did you install anything when this started?
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1209070-need-help-immediately/#findComment-13715181
Temperatures? How old is your Windows install? RAM usage?
Also don't use UsErBeNcHmArK, it's very misleading in most cases.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1209070-need-help-immediately/#findComment-13715186
If you are concerned about disk health, use crystaldiskmark.
And also change your topic title, there is no fire.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1209070-need-help-immediately/#findComment-13715189
