Budget (including currency):  10,000 mxn more or less
Country: Mexico
Games, programs or workloads that it will be used for: Design
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  First time computer buyer/builder
Hello everyone I'm looking to build a pc, mainly I will use it for design purposes (photoshop, light gaming, drawing, light video editing etc) I have no idea what to look for or where to focus my budget the most on. Of course, the less I spend the better. Also, I'm not looking for the highest performance but certainly I would like a good bang for buck kind of thing. If I could include the monitor and peripherals (mouse and keyboard) that would be ideal but not mandatory for now.
Thanks in advance!
https://linustechtips.com/topic/1208966-help-with-new-build/
38 minutes ago, Not Wills said:
us dollars? as a ryzen 5 3600 is $8k in Mexican dollars
500 dollars US approximatley
27 minutes ago, Not Wills said:
eeeeeeeeeee. Im finding lots of good price to performance stuff but its over you budget
I dont mind going a bit over budget, its more or less to give me an idea
https://linustechtips.com/topic/1208966-help-with-new-build/#findComment-13714534
Are you buying in USD? If not, don't use USD as a price definer, it's irrelevant to you.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1208966-help-with-new-build/#findComment-13714563
15 minutes ago, RobRdz said:
Just thought putting that currency would be easier to reference from different countries
It's not.
Not all parts are available everywhere, and prices aren't the same country to country; what costs $50 USD does not cost the equivalent currency in another country.
https://linustechtips.com/topic/1208966-help-with-new-build/#findComment-13714612
