cpu HELP Ryzen 7 2700x stuck at 3.2Ghz
Solved by Senzelian,
First check your WIndows 10 power management settings.
The minimum CPU power needs to be set to 5% or lower and the maximum needs to be set to 100%.
What often happens with Ryzen 2000 chips in Windows 10, is that both CPU power options (min and max) are set to 100%.
This means that cores can't clock low enough for the other cores to turbo up.
It's in German, but you get the point:
Featured Topics
Bobzcpu ·
Posted in Power Supplies2 -
1
RZBAKA ·
Posted in New Builds and Planning5 -
1
Magnumenforce ·
Posted in Phones and Tablets2 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
6
