a UPS is downright excessive for a gaming PC. It is a bummer when your PC unexpectedly shuts down, but a storage backup of your save files to prevent corruption is all you need. You can just choose what files you want to back up to something like google drive
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1208378-do-i-need-a-ups/#findComment-13709624
3 minutes ago, wassil said:
just finished my first gaming pc i was thinking do i need a UPS ?  where i live there is still constructions going on sometimes the electricity cuts off
are this cuts dangerous for my pc or will harm my componements ?
power cuts could damage your pc parts if your unlucky, or corrupt your os/files, so a ups would help, but ya just having a backup of your data is probably fine
https://linustechtips.com/topic/1208378-do-i-need-a-ups/#findComment-13709636
so electricity cuts won't damage my pc or psu ?
https://linustechtips.com/topic/1208378-do-i-need-a-ups/#findComment-13709637
Power surge could power shortage could not
For the most part no unless you need continuous power for something or you need a ups if Power cuts out very consistently
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1208378-do-i-need-a-ups/#findComment-13709638
not really, a good PSU has loads of protections already, and generally it's a power surge that causes damage, not a power cut. You can also buy an inexpensive surge protector to bolster your setup, they can be found under $20 usually.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1208378-do-i-need-a-ups/#findComment-13709642
