This doesn't really matter in the larger scheme of things, but a PC Speaker came with my case and my motherboard (D3SH Wifi) has a 4 pin header for the speaker in its F Panel.  I figured I might as well connect it.  But the problem is that the pins don't seem to be tight enough so when I turn the case so the motherboard is sideways the speaker immediately falls off.  Should I try to tape it in place?  Would you recommend scotch, masking, or duct tape?  Or should I just leave it out completely?  Thanks.
https://linustechtips.com/topic/1208352-loose-pc-speaker-connection/
Out of 4 cases I've purchased, this is the only one to come with a speaker.  It's the DEEPCOOL MATREXX 30,Mini-Tower.  It's a nice little case that comes with a tempered glass side panel and was only $35 5 days ago on Amazon.  I think that price was too good to be true as it's now going for $63.
I'm going to leave the speaker out.  Thanks for the advice.
