Need a compatible power supply
Solved by Mateyyy,
11 minutes ago, Updagloop said:around £100 (im in the uk so sorry if you can help)
Going by prices on PCPartPicker, you can get a Corsair RM550x for 87 quid or a be quiet! Straight Power 11 550W for 99 quid.
You could spend less obviously, but if you have the money I'd go for either of the two units above. You never want to skimp on the power supply and heck in the long run this could save you some money, as a really high-end PSU could last you multiple upgrade cycles (depending on how often you upgrade your PC).
If you're interested in looking up some other options, you can check the forum's PSU tier list here:
