How to use single drive?
Go to solution Solved by mgsstar,
Yes you can put your files in your operating system folders (Desktop, Documents, Downloads). You could also create a folder in C drive to put your files into.
If I am building a budget system, and with the budget of this system, an SSD can't happen, how to use computa? Lol. If I only have one hard drive, I install windows to it obviously, but how will I save word documents and stuff? Is it ok to put it with the operating system folders? (I have always had an SSD on a computer where I actually saved something). Can someone explain how I would save pictures, documents, etc...?
Thanks in advance.
https://linustechtips.com/topic/120831-how-to-use-single-drive/
The drive that your OS is on, the C: drive, everything you download ans save will go onto that drive. The OS folders are all pretty much hidden and with one drive there are file path's that  you can normally choose from of where it goes on the drive.
https://linustechtips.com/topic/120831-how-to-use-single-drive/#findComment-1609096
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/120831-how-to-use-single-drive/#findComment-1609101
