hey, im runing a ryzen 7, 3700x on a B450 E asus rog strix MB with a Corsair H100i RGB PRO XT AIO cooler, but for some reason im at 50c on idle , ambient temp is about 21c
its my first time installing a AIO and im not sure if ive done it right or not, ive connected the 3 pin connector to the CPU_Fan header(3 pin but only with one cable, not 3), and the sata power to sata power and connected the usb for corsair link. the AIO came with pre applied paste, but im tempted to change it out with cooler master mastergel maker paste that i have, i have the radiator in the front with the fans set as intake.
im using corsair vengeance rgb pro 2x8gb 3200mhz .
anyone got some tips or hints for me so i can sort out this 50c idle problem?
https://linustechtips.com/topic/1208195-cpu-idle-temp-50c/
It's either 3 fan radiator or a top end air cooler to see better temps.
The idle temps are not so important as the full load ones, if the full load temps are good then you are fine.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1208195-cpu-idle-temp-50c/#findComment-13708390
Ryzen is super inconsistent in idle temps
Use ryzen master or hwinfo64 to monitor temps and either way idle temps don't matter if load temps are good
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1208195-cpu-idle-temp-50c/#findComment-13708399
Make sure you're running the latest BIOS and chipset drivers, and use Ryzen Master or HWiNFO64 to check temperatures.
Either way, I really wouldn't call 50C at idle "a problem". Ryzen tends to run warmer at idle because of its aggressive boosting behaviour (hence the also higher voltages at idle), so it's perfectly normal if it runs warm and/or you notice temperature spikes. If anything, you could try applying a slight negative core voltage offset in the BIOS - you can generally do at least -0.05V to -0.1V without losing any performance and lowering temps by a decent bit.
As mentioned above, again, load temps are a lot more important than idle temps. If those are normal, then you're good.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1208195-cpu-idle-temp-50c/#findComment-13708413
