On 6/11/2020 at 7:53 PM, Kanna said:
Most fan hubs connect with normal fan plug and sata try that
His talking about ARGB, not fans.
Question is, do you really want ARGB or is RGB enough. If you really want ARGB, then options are to change mobo or get ARGB controller (EK Look Connect is one with software). If you are fine with RGB, just get RGB fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Yeah I didn't understand that one thanks for pointing out
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
