what ?
slower mobo ? what is that ?  do you mean what speed it can support ?
specs ? budget ?
cpu?
Edited by TofuHaroto
correction
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1207858-help/#findComment-13705611
7 minutes ago, TofuHaroto said:
what ?
specs ? budget ?
cpu?
sorry im not good at explaining I want to get 32gb of ram and the only one I like is 3200mhz and my motherboard is 2400mhz will my pc clock down the ram so it can run.
https://linustechtips.com/topic/1207858-help/#findComment-13705648
what mobo do you have ?
Build Log:
https://linustechtips.com/topic/1207858-help/#findComment-13705657
3 minutes ago, slaapzz said:
I have the H110 PLUS and my cpu is the i7 7700
it will support up to 2400
meaning the board will run the sticks at 2400
Build Log:
https://linustechtips.com/topic/1207858-help/#findComment-13705865
Just now, slaapzz said:
if I put in 3600mhz will it clock the speed down to 2400mhz???
yes the board can only support up to 2400
Build Log:
https://linustechtips.com/topic/1207858-help/#findComment-13705892
so yes it will clock down so I can use my pc
yes
Build Log:
https://linustechtips.com/topic/1207858-help/#findComment-13705900
