So I just got a new motherboard and tried turning on my xmp profile so I can get the rates 3200 speed but when I do this the oc gets stuck in a boot loop and won’t boot, aside from this when I turn on xmp the voltage number turns red in the bios meaning it’s probably not a safe voltage, what do I do?
https://linustechtips.com/topic/1207602-xmp-help/
Nah 1.35v memory voltage is more than safe
Desktop benching:
https://linustechtips.com/topic/1207602-xmp-help/#findComment-13703801
2 minutes ago, LilPach said:
So why does it turn red in the bios, and why is it stuck in a boot loop?
turns red in BIOS because no one bothered to set proper voltage limits and warnings in the BIOS. Just ignore it.
As for boot loop, maybe you lost the silicon lottery on the CPU memory controller or didnt use a capable board. Memory stick configuration also matters
Desktop benching:
https://linustechtips.com/topic/1207602-xmp-help/#findComment-13703824
I just did it again and it booted into windows, so should I just ignore the red text as long as I don’t get the boot loop again, I’ve used this memory before the exact sticks and worked on my old mobo which is much weaker than my current board
https://linustechtips.com/topic/1207602-xmp-help/#findComment-13703829
