I'm building a new build and when I received the motherboard, a capacitor by the PCI slot was bent over by about a 30ish degree angle. I bent it back into place but my build sends no signal to the display. Everything turns on and sounds like it is running. I've tried a different GPU, I've tried one stick of RAM at a time, nothing. I currently have it plugged into a TV through HDMI, and when I turn it on, it takes the TV off of standby, but never shows any video. Any ideas?
https://linustechtips.com/topic/1207601-no-display-bent-capacitor/
4 minutes ago, The_russian said:
What are your specs? Sometimes capacitors are bent at an angle from the factory so that probably isn't the problem, especially if it is still connected just fine.
Cpu: Intel i5 9400F
Mobo: Asrock Z390M-itx/AC
RAM: Corsair Vengeance LPX 3200 2x8 (haven't oc'd because I've never gotten into bios)
GPU: ASUS Tuf 1650 Super
PSU: Corsair CX 450M
SSD: Kingston 240GB
HDD: Barracuda 2TB
Cooler: UpHere Red AIO
