No mobo mentioned.  Also ram speed may be an issue.
”flickering” implies PSU issues or a bad connection depending on what you mean by flickering.
also that cpu was released in 2013.  Might be new to you but it’s used stuff.
The motherboard is a ga-h97m-d3h gigabyte and the ram and cpu I got from a prebuilt it is sram ddr3
On 6/11/2020 at 2:13 AM, woodlandgamer said:
The power supply is brand new
That means nothing
What PSU ?
Have you tried clearing the cmos ?
Phone: Pixel 3a (Purple-ish).
Build Log:
  • 1 year later...
I never found out the problem but it did work when i bought a new mobo and cpu as the mobo was used before hand which was probably the source
