There is a marginal difference
Meaning that air is being suffocated and your not getting good airflow
Temps are fine in both situations but the airflow is clearly lacking in the case
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1207274-adequate-cooling/#findComment-13701205
13 hours ago, dfsgsfa said:
its the cooler master 355u , really basic stuff
Whats your GPU? CPU temps can be better by adding side intake on upper slot. GPU possibly too.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1207274-adequate-cooling/#findComment-13704512
13 minutes ago, dfsgsfa said:
sapphire rx570 nitro, temps are exellent at 62C with only 20% fan in ideal cooling
and peak at 36% fan
With side panel off? That's kinda telling that case has bad airflow.
Lower side fan could be either way.
https://linustechtips.com/topic/1207274-adequate-cooling/#findComment-13704621
