probably to many variables to take into account its probably just very difficult.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/12070-right-angle-24-pin/#findComment-128775
That sounds like a great Idea, It would hide the often ugly 24-pin power cable!
If I were to make a guess, the small indent on the socket where the clip on the power cable goes is always on the south side of the connector, right angle would obstruct that, causing a form-factor change.
Ryzen 5 1500x, Noctua NH-L9x65 SE-AM4, GA-AB350N, 16GB 1600Mhz, EVGA GTX 970, 250GB Samsung 960 Evo, 120GB Samsung 840 Evo, 1TB WD Green & 2TB Seagate Barracuda. 650w OCZ ZX & Cooler Master Elite 130. Acer CB241HQK 4K, LG IPS234V-PN 1080p, Ducky Zero Shine All Blue/Anne Pro Brown/SteelSeries Apex Pro & Razer Naga 2014
https://linustechtips.com/topic/12070-right-angle-24-pin/#findComment-128817
That would be extremely hard to plug in, you might have to do it before you mount your motherboard.
Case: Corsair 350D Windowed Motherboard: ASRock Pro4-M CPU: Intel i3-3320 Cooler: Stock(upgrade) Memory: Corsair Vengeance 8gb 1600MHz Red GPU: Asus GTX DCUIIOC 650 ti  PSU: Corsair CX500 SSD: Samsung 840 128Gb
  Monitor: HP 2159M, Random DELL 1280x1024 Keyboard: Corsair vengeance K70  Mouse: SteelSeries Black Ops 2 edition Mouse Pad: Unsure Headset: SteelSeries Siberia v2 Blue Frost edition Labtec LT-820 Microphone: Blue Snowball: Frost
https://linustechtips.com/topic/12070-right-angle-24-pin/#findComment-129328
Well they need to take into account all of the situations where it won't work, and weigh that up against the benefits of it (which are really only aesthetic).
From the manufacturers point of view its really not worth it to lose a bit of board space and potentially create compatibility issues with a lot of cases.
https://linustechtips.com/topic/12070-right-angle-24-pin/#findComment-130557
I like how I'm googling right angle 24 pin adapters and this was the 5th response on google.
Rig 1 CPU: 3570K Motherboard: V Gene GPU: Power Color r9 280x at 1.35GHZ  RAM: 16 GB 1600mhz PSU: Cougar CMX 700W Storage: 1x Plexor M5S 256GB 1x 1TB HDD 1x 3TB GREEN HDD Case: Coolermaster HAFXB Cooling: Intel Watercooler
"My day so far, I've fixed 4 computers and caught a dog. Australian Tech Industry is weird."
"It's bent so far to the right, It's a hook."
https://linustechtips.com/topic/12070-right-angle-24-pin/#findComment-130678
  • 3 years later...
EVGA X99 Classified has right angle connectors.... And a 24pin...
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/12070-right-angle-24-pin/#findComment-8295282
