The display in question is samsung SyncMaster 971p to whom it may concern, this started happening recently, and it doesn't happen on my other display. i tried switching the display outputs, but nothing changes. the first image is of my HDMI display and the 2nd is from the display in question, i know the pic quality is poop but artifacts are clearly visible. I tried running the HDMI display on DVI to check if my port is broken but no artifacts occur.
20200609_193745.thumb.jpg.30234184876e2dc8b473be97922b3545.jpg20200609_193742.thumb.jpg.f2eb7358240361dc10f25dbc4aa78a4d.jpg
https://linustechtips.com/topic/1206903-whats-wrong-with-my-display/
So you don't have artifacts with DVI? Have you tried a new cable?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
5 minutes ago, VGS_XD said:
I could try to run the display trough an HDMI cable using and adapter, but i dont have any spare DVI Cables to test.
The cable might be the one to blame here, i switched the outputs on the displays and rebooted my system and now its the HDMI Display that's having issues. but then that doesnt seem like its the cause as the issue fixes itself when i yank the cable out of my gpu and plug it back in, so maybe windows update fucked something up, like it may be trying to run the display at 10 bits or smth
Sounds like a cable issue if replugging works.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
