Mh depends how you define small.
The 212 EVO from Coolermaster is very inexpensive and very good.
It's also quite a bit smaller than other tower coolers.
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
get something like this of you can fit in it in its small enough its cheap
http://pcpartpicker.com/part/corsair-cpu-cooler-h80i
Specs
Price/Performance goes to the Coolermaster Hyper 212 Evo hands down. Also whisper silent if acoustics is an issue for you. If you want something smaller then something like a Corsair H80i or H60 will do but they are both quite a bit more expensive.
CPU: 4670k 4.2GHz @ 1.25v | MotherBoard: Asus Z87i-Deluxe m-ITX | Ram: 16GB Corsair Vengeance 2400Mhz | GPU: Sapphire HD7970 GHz Vapor-x @1190Mhz/1625Mhz | Case: Bitfenix Prodigy (White) | Storage: Samsung 850 Evo 240GB, Kingston HyperX 3K 120GB, Seagate Barracuda 2TB | PSU: Seasonic 650W G Series 80+ Gold | Monitor: Asus VS239H-P 23" | Heatsink: Corsair H100i with SP120 PWM Performance | Keyboard: Corsair K70 (Cherry MX Red), Corsair K70 RGB (Cherry MX Brown) | Mouse: Corsair M95
I am looking for a cpu cooler that is either liquid or air cooled. Right now im planning to buy the be quiet shadowrock. I know this is not small but right now its the cheapest and best option. I am using a i5 4670k if that helps. Thanks
Try corsair h100i or corsiar h60i, depending on the fit. with Noctua NF-F12 fans (if i'm remembering the model correctly)
Nothing to see here, move along
How small?
