2 minutes ago, Berkomeister said:
It's great. cpu and gpu should play well with each other
Just now, chery said:
im in america budget is around 800 usd
mainly i wanted to know was if the motherboard would work with 3rd gen cpu r53600
thanks for the  replies
https://linustechtips.com/topic/1206697-i-need-help/#findComment-13696649
Get a Max mobo from MSI, they have guaranteed Support for the latest CPUs form AMD. If you're ONLY gaming the 3300X will actually perform a bit better than the 3600 while being cheaper. If you do ANY productivity work the 3600 will serve you better overall.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1206697-i-need-help/#findComment-13696710
45 minutes ago, chery said:
is this build fine if not what should i do [i havent built it yet]  thanksssss
mobo:Asus Prime B450M-A
cpu: ryzen 53600
gpu: gtx 1660 super 6 gb oc
PCPartPicker Part List: https://pcpartpicker.com/list/phDbHB
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($166.89 @ Walmart)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard  ($72.99 @ Best Buy)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($82.99 @ Amazon)
Storage: Kingston A400 240 GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce GTX 1660 SUPER 6 GB VENTUS XS OC Video Card  ($239.99 @ Newegg)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($58.98 @ Newegg)
Power Supply: EVGA BR 600 W 80+ Bronze Certified ATX Power Supply  ($92.48 @ Amazon)
Total: $809.30
Generated by PCPartPicker 2020-06-09 05:33 EDT-0400
this is a complete build for 800 if you want it. Same cpu and gpu but changed the mobo and added the other stuff.
https://linustechtips.com/topic/1206697-i-need-help/#findComment-13696746
Total: $809.30
The setup is great for 1080p 60fps gaming in almost all games released till date though in few games you will have to reduce some settings to Medium/High But overall it's a great setup.
System Specs:
  • CPU: AMD Ryzen 5 2600 @3.40ghz (6C/12T)
  • Motherboard: Asus Prime B450M-K
  • RAM: Corsair LPX 2*8GB DDR4 @3200mhz CL16
  • GPU: Zotac Nvidia GeForce RTX 2060 (TU-104 variant) 6GB GDDR6
  • Case: Antec GX202
  • Storage
  • SSD: WD 240GB,
    HDD: Toshiba 1 TB @7200rpm
  • PSU: Corsair CX550 (2017 grey unit)
  • Display(s): BenQ 22 inches monitor, 1080p @ 60hz
  • Cooling: 3 Antec case fans 120 mm (2 blue LED front intake and 1 non LED rear exhaust)
  • Sound: Behringer UMC22 USB Audio interface, AudioTechnica ATH M20x studio headphones
  • Operating System: Windows 10 Pro 64 bit.
https://linustechtips.com/topic/1206697-i-need-help/#findComment-13696803
