help me choose a motherboard for ryzen 5 3600
Solved by Guest,
16 minutes ago, Dimondminer11 said:You could probably even get away with something like a 2700 on a board like that and still be fine.
It'll be so power limited and likely throttle, never reach potential boosts and eventually burn the VRMs.
You want to know the capability in current (Amps) the board is capable of before making a suggestion like that.
So the B450M-A (I actually have one) is 50a capable. No good.
The B450 Gaming X is 75a OK for 3600
B450 Arous M is also 75a OK for 3600
None ok for Flagship Zen+
