Somethings wrong with my DNS. I can connect to skype/steam but not anything else. I went into my network proprieties and set my DNS to automatic, click okay and everything works for 10 seconds ish, then the DNS resets to 127.0.0.1 and it doesn't work again. HELP :(
https://linustechtips.com/topic/120629-help/
Still 127.0.0.1?
Hmm.. try changing it back to auto once more, although i dont think that will work now its worth a try.
This might be something more complicated. Do you have up to date anti virus?
I have a free AVG. I've run scans on that, malware bytes and windows defender, it found 4 trojans which were removed.
https://linustechtips.com/topic/120629-help/#findComment-1606612
Ok well it wont be that. Are you using wired or wireless?
Do you have a virtual computer on your pc? Or has virtual computer software ever been installed on there (you will see virtual network ports).
Last question haha, what version of windows are you using?
Wired, windows 7 and by virtual pc do you mean like hamatchi? I have hamatchi, had it for ages
https://linustechtips.com/topic/120629-help/#findComment-1606647
