Hmm thats odd.. well if its working then best leave it i think.. if it stops working again then more investigating will be needed.. fingers crossed!
Welp, my pc restarted again and now it's doing the EXACT same thing. I have tried everything I have done previously but it's just resetting again. This is really starting to annoy me now.
https://linustechtips.com/topic/120629-help/page/2/#findComment-1632897
Go back to command prompt and type netstat -b
This will show all TCP connections and which programs are using them. Have a look for anything suspicious and write them on here
I just found a copy of Windows 7 lying around, so im doing a reformat to see if it makes a difference.
https://linustechtips.com/topic/120629-help/page/2/#findComment-1677145
