Hey everyone, So i'm planning on building a pc... I know how to build it and everything... I used to build and mess around on quite old pc's.... And i need help.... So in the text doc i attached.. Can someone please tell me what parts or things im missing.. Thanks
https://pcpartpicker.com/list/sKTQsk
https://linustechtips.com/topic/1206182-i-need-some-help/
instead of a text file, you should create a pcpartpicker.com list so that we don't have to download anything.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13691992
@Loozher your thread was moved to the appropriate section.
As someone mentioned, there's a website called PC Part Picker, it helps with making build list ;
You can make a list and then share the link so that everyone can see the build and modify it to help and share back the link to the modified build.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692021
Alright thank you
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692025
I just changed it to pcparkpicker, thank you
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692039
You copy/pasted the website URL, the one you need to copy/paste is the one I circled in red ;)
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692061
24 minutes ago, Loozher said:
Tough to recommend 9th gen intel, either ryzen or 10th gen is what you want.
What is the main use for this PC?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692123
31 minutes ago, Loozher said:
Mainly Gaming and recording/streaming
Are you buying in the united states?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692174
Primary PC:
PSU tier list
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692240
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692247
They're basically the same.  But go for the 10700k if you can for the newer motherboards and better support.  And if your just gaming, the 10600k is a great way to save a bit of money because it completed handily with the 9900k in games.
ALL AMD ALL THE TIME: AMD Ryzen 9 3900x | 32GB DDR4-3600 CL16 G.Skill RAM | Gigabyte x570 Aorus Master Motherboard | Powercolor RX 5700 XT Red Devil | 1TB Samsung 970 Evo M.2 NVME Boot Drive | 1TB Samsung 860 QVO Game Drive | Lian Li PC-011 Dynamic Black Case | Corsair RM750 Power Supply | Corsair H150i Pro 360mm Liquid Cooler | 7x Noctua NF-P12 120mm PWM Fans | Acer XV272U 27" 1440p 144hz IPS & VG270U 27" 1440p 75hz IPS | Logitech G610 Keyboard, Z625 2.1 Speakers, C920 Webcam | Glorious Gaming Model D Mouse | Focusrite Scarlett Solo USB Audio Interface | Audio Technica AT2020 Condenser Microphone | Beyerdynamics DT770 Pro Headset | Kingston Cloud Revolver S Headset |Microsoft Windows 10 Professional
Main hoe turned side piece NAS/HTPC/f@h slampig: Intel i7 4790k under Corsair H105 | ASRock Z97 Extreme 4 | 32GB DDR3-1866 Crucial Ballastix | EVGA GTX 1070 SC | 250GB Samsung 850 Evo SATA drive | 2TB Western Digital Green HDD | NZXT H440 | Microsoft Windows 10 Pro | 55" Samsung 4K QLED
Support Stack:  Cyberpower 1300VA UPS backup | Google Nest Wifi + Gigabit Fiber Internet | Raspberry Pi 3 pihole | 2x Unmanaged Netgear GS308 Switches
Pre-ordered and on it's way:  Ducky Mecha Mini v2 w/ Cherry Browns.  On the road to De-Logiteching my rig.  Keyboard/Mouse down.  Webcam/Speakers to go.
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13692370
7 hours ago, Loozher said:
Would a i7-10700k or i9-9900k Be better  for gaming?
No, gaming focused PCs need only 6 cores right now. An i7 with 8 cores might help if you esclusively want to stream with the CPU, but using nvenc off the 2080 ti will also deliver a very high quality stream.
5 hours ago, koptr said:
If you wanna spend that much money, you should wait for big Navi / Rtx 3000.
That's at least september away, with no actual concrete release date. If OP needs a PC now and not in a few months, there's no point in waiting that long.
22 minutes ago, Loozher said:
Whats a good Motherboard for a i7-10700k? Since it's LGA1200 it wont fit with the z390 Aorus pro
I linked a Z490 motherboard in the build list I made
Primary PC:
PSU tier list
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13693302
I have a pc at the moment, You can see the specs in my profile.. But i am looking for an upgrade.. I can still run games fine but when games start getting harder on specs im gonna need it
https://linustechtips.com/topic/1206182-i-need-some-help/#findComment-13696795
